Hi,
2003 Sonoma SLS ZR-2 4WD.
Went to change the oil and filter today. The oil filter is mounted in front, behind an access door that is opened via a screw type latch. The oil filter mounting thing is loose and obviously broken. Lines going into it and out of it. Look like the casting broke where it is bolted up to the engine.
What is this part called? Is it a common part I might find at an AutoZone or Advanced Aoto Parts Store?
How bad it it to replace? Oil lines look pretty much OK, no dripping. How are the lines mounted, manifold like mount, i.e. both lines held in with a single bolt through some kind of fitting the I may need new seals for? There are two lines in, two line out.
Any advice is greatly appreciated. I want to fix today/tomorrow but might just have to put oil back in without changing the filter this time.
THANK YOU
THANK YOU
