Determined
- Aug 12, 2023
Has anyone else had the problem after changing the oil in a 2021 Denali 1500 6.2L engine where you tighten the oil filter hand tight then a little more with a wrench, but after a short period of time comes loose and you finally notice when there is an oil puddle under the truck. you go check the oil and it's 2 quarts down. I had it happen twice, once when I changed the oil and once when a shop did it.
Fixed the problem by tightening it down with a wrench. A lot tighter than you normally would.
