oil leak
mickeyt
Wow i have this thing 2 days now. put about 20 miles on it now its leaking alot of oil only when its running. I noticed it smoking going up a steep hill. a lot of oil all over the under carriage.only leaks going up a long hill. any info as to what this might be ? I am so sick over buying this jimmy Thank you
Common things to inspect are the oil lines to the remote oil filter and the oil pressure sending unit which is located by the distributor on the block i self.
Good luck and keep us posted. :D
Thank you MOLSON I drove it again yesterday and may have discovered yet another problem. I was driving along and heard a humming sound comming from the passenger front side. It got louder as driving then when i pulled over it sounded like a gear or something grinding. then when i pulled away it gone. What do you think.
