p0300 misfire 2008 sierra 5.3
Pharaoh
my scan shows misfires on cylinder #2 & #4 also have sir codes B0081-71, u0155-00, u0170-00 and EBCM code c0561-71. I am getting spark at the plugs, pulled the #1 & #2 plugs and they look the same, changed them less than 2 months ago as well as plug wires. not sure where to look now. if i unplug the coil on the #2,4,6,8 it does not seem to affect the miss. i'm no car tech just a home doityourselfer. lol any pointers i would greatly appreciate
tmurphyxzy5q
So, if you have a miss on these two cylinders, and disconnect the control wires/connector from the coils, and it runs the same, you apparently have bad coils. If replacing those doesn't do it then I hate to say it, but the ecm's control signal could be interrupted via any number or reasons. Try swapping the coils to see if it follows the coil.
Pharaoh
thanks for the reply tmurphyxzy5q, after trying to figure it out on my own i took it to a garage for them to figure it out turns out i have major engine damage so i have to have a new motor.
