windswept4
- Mar 17, 2025
The parking brake cable equalizer on my 1998 GMC Sonoma (same as the Chev S-10) is under the driver door and it has a 12 MM hex nut on the threaded end of the cable that continues on to one of the rear wheels. I grip, with vice grips, the square stock of the brake cable at the point where the threading begins and I use a 12 MM open end wrench on the hex nut. With that excellent leverage and grip on the cable and the nut, the nut won't break loose and turn on the threading. It's been soaking in PB Blaster for 3 days now. Should I heat the nut with MAPP gas until red hot, quench quickly in cold water and try turning the nut again? Or is there an easier way to get that 12 MM adjusting nut to turn?
