pls help ASAP GMC Jimmy Automatic SLE
Jimmy1995
san antonio, texas
Im having electrical problems that seems like every time I drive my jimmy with its head lights off its hard to run any other electrical appliances like radio or ac and i have to turn down my dash lights or my jimmy acts like it wants to die and my volt meter bounces. Even just with the head lights it still seems like it wants to die. If my head lights aren't on I can run everything and it runs great. I cleaned the terminals and checked all the ground wires and it still acts funny. I am having other problems to like abs light been on since i bought it and i cant find anyone to pull the codes. I also have problems with sometimes i put it into drive or reverse it slams but neutral or park its fine. I checked the tranny fluid many times and it doesn't seem to have any problems switching gears while moving.
Update
I put in a new alternator and fuel filter and air filter still no luck.:mad: I will be replacing the spark plugs tomorrow but i doubt that has any connection to the power between the alternator and the ac. Any other ideas. my ac blows cold i also checked the Freon in hopes maybe i was to high or to low but it was great i also checked to see if the clutch is spinning with the compressor and everything looks great it also blows cold air.:mad::mad::mad:
update
I put in new spark plugs looks like the previous owner never did a spark plug change or any basic tune ups. The spark plugs were so rusted over and the tips were white and i went to grab onto my 6 spark plug wire and it literally fell apart i took it for a spin afterwards kind little hesitant but i am out of money to buy a ditributer cap or rotor so maybe thats my problem:confused:
update
Ok i replace the distributer cap and rotor and noticed they bother were so far gone go figure right the previous owner only did oil changes on time never tune ups or anything else but now my volts dont bounce its my rpms only at idle not bad but to the point i know its not normal any suggestions now wats next it has a new egr valve i may just try 44k and see what that does for me
