possible to swap a 95 gmc engine with 96 chvy 1500 engine
austinpowers
wondering if possible to swap engine in a 95 gmc sierra 1500 with a chvy 1500 v6 vortec engine and what would be needed to change in gmc to get that to work, is it even worth doing
Not worth doing the swap. The 96 was configured differently from the 95, if you are going to do that. It would be much easier to swap out the wire harness and PCM rather then to take the engine apart to swap out parts and sensors needed for the two different PCM system being used. The block and heads are interchangeable, but you have a totally different type of fuel delivery system.
Sorry for the bad news and good luck with your project. ;) Keep us posted.
