Hello,
Hopefully this is the right forum to post this:
I have a 2002 Sierra with the 5.3L v8. It has 134K Miles.
This weekend when I went out to start it in the morning after it had been sitting all night, it had a noticeable ticking sound coming from the motor that I had not heard before. After a few minutes the ticking sound went away. Earlier last week the "Low Coolant" message came on the message center. I refilled with dexcool and water 50/50 mix. When I looked at the coolant reservoir this weekend, it was low again by 1.5 inches or so. I changed the oil in it this weekend since it was due. It took a long time for all the oil to drain out of the pan and towards the end there were black specs in the oil that was draining. It was not metal flakes as the black flecks would dissolve if pressed between my fingers. It seemed like sludge. The oil pressure has been a little bit high and the engine oil cap has some fluid in the top and it smells like coolant pretty bad. The temperature gauge has been reading normal but i fear it might be a head gasket going out. The ticking sound happened both mornings this weekend but went away after a few minutes. There was no ticking sound this morning when it had sat all night. The oil looked normal when I changed it. It has been using a little coolant but has not overheated and is running normally.
Any ideas or insight would be appreciated.
Feel free to ask for any clarification.
Thank you,
Tony
Thank you,
Tony
