Reassembly of top of Steering Column
cntinuum
Vancouver, WA
I replaced the turn signal switch. I pulled off the top "can" to route the wires. I am having trouble reassembling the steering lock and dimmer switch into the "can". Can't find any discussion on this or found a diagram.
Thanks,
-Dave
Solved
Well, I figured it out. I ended up removing the ignition and dimmer switch off the steering column so I could see more of how to engage the "rack and pinion" of the ignition key tumbler. The "pinion" gear that the ignition cylinder engages, has a block that goes in the position below the teeth in the "rack" that is connected to the rod that operates the ignition switch. Took about 4 hours to get everything put back together. Never did find anything to be an aid.
Cheers,
-Dave
