Happened as I started to drive away from the place says error p0740 tcc solenoid circuit
He disconnected it and it still don't work
Good/bad News
Found fuse for pcm blown so replaced it and same problem so going to replace it but just so I can be sure on this the pcm is the whole unit under the hood by tje battery? And will the one from a 99 chevy 1500 work if it is the same motor and tranny
If the pcm went out would the diagnostics tool show more than one code
Turned out to be pcm... What wrong connection could of caused this?
