There Is A Grinding Sound Coming From My Right Front Wheel Well, I Just Put New Rims And Tires On, And Put A New Sway Bar Link On As Well. But The Problem Persists. Does Anyone Know What The Problem Could Be??
Check the back brake dust plate, it may be bent in to the rotor causing your grinding noise if there is no signs of brake problems. Easy fix with a long screw driver and it just a matter of pushing the dust plate back away from any moving parts. Good luck and hope this is the grinding noise your describing.
