rim size
88longbed
what is the proper offset and backspacing when buying rims for the 88's. I just found a good deal on a set of rims but to order you have to put in backspacing and offset.
Log on to http://www.tirerack.com/, you can find a set of rims there with the backspacing and offset you need on your Sierra. Note there is a difference betwen the 4wd and 2wd Sierra.
Good luck and hope this helps you. :D
