Rotor rubbing grooves into caliber
DS jimmy
The outside edges of my Rotor are grinding grooves into thiinside top of my caliper
Rotors should never contact the caliper unless something isn't installed right. Bolts or pins hold the caliper in place. Check for broken pins/bolts on both the caliper mounting and the caliper bracket.
Already have tight and on correctly. Replaced the Caliper due to a blown seal
Found rubbing marks starting on the old caliper drove the next day and the new caliper did the same thing but worse. Replaced the master cylinder as well. Still the same issue I have read a few things that stated it might be air in the system locking the brakes and sucking the master cylinder towards the rotor or possibly bearings or bushing issue. The assembly bracket is also rubbing.
You definitely have something wearing out. The only thing that really moves in the disc braking system is the piston inside the caliper. The piston side applies the pressure to the brake pad pushing it into disc causing a slight movement (sideways only) of the caliper which causes the other brake pad to contact the rotor. Maybe I'm not understanding what you are considering the caliper or where the grooves are getting rubbed into it. I can only imagine that the rotor contacting the caliper would result in a lot of noise.
Air in the brakes would cause loss of pedal and braking ability. The brake pads are almost running against the rotor constantly, the piston in the caliber will be pushed back into the caliper by the pads, as the pads wear the piston will stay out further and further until the pads are completely worn. This is why the brake fluid level will drop in the master cylinder.
Given the last statement of the bracket assembly also rubbing, I would tend to lean towards a bearing issue allowing excessive movement of the hub assembly, but that would have to one really worn out bearing.
When everything is installed correctly, the pads should sit approximately centered in the braking surface (machined part) of the rotor. There will be a thin line near the outer edge where the pads do not contact and there will be an area of the rotor near the hub that the pads also will not contact. There should be nothing loose enough to be moved by hand. What I would consider to be the top of the caliper spans over the rotor and has a pretty good sized hole to inspect the brakes through, that part of the rotor should be a pretty good distance from the rotor itself. The hole is big enough to see the thickness of both brake pads.
If you can, try to post a picture of what you are seeing.
One other thought occurred to me, if the rotors have recently been replaced they might not be the correct rotors and are too large.
I'm sorry if I come off sounding like an a**, or that I am trying to talk down to you, I am not. I am just trying to wrap my head around the rotors rubbing the caliper without there being a major issue.
