I have a 2002 GMC Sonoma Extended Cab 2WD with the 2.2L 4 cylinder engine with a little over 100k miles and the service engine soon light just popped on the other day. The codes that came up are
P1137 Heated oxygen sensor - Bank 1 Sensor 2 (H02S12) low voltage during power enrichment mode
Failed H02S12 (bank 1 sensor 1) heater circuit
P1632 Theft deterrent system fuel disabled
Faulty circuit or Failed BCM
P0705 Transaxle range switch fault
Failed transmission range sensor
P1441 EVAP system flow during non purge condition
Failed canister purge solenoid or failed fuel tank pressure sensor
Would anybody be able to help explain where I would find these sensors on my vehicle so I can replace them?
