joshua2903
- Apr 6, 2013
so recently my 95 GMC is running like crap, the truck has always been maintained it has 215,000 +or- I firsst noticed some slugishness while driving so I had the fuel system flushed(turns out this is NOT recomended by GMC and is a BAD IDEA) the flushing actually made things worse, the tech actually changed my fuel filter before flushing so I assume he flushed everything into the new filter, I took the truck home and replaced the fuel filter,EGR valve,idle conotrol actuator and the purge valve actuator. now the truck will idle fine if its facing downhill until the truck reaches the operating temp then the service engine soon light illuminates(code 32) if the truck is facing uphill the truck will idle very rough, what could cause this? could it be the fuel pump? or maybe the cheap-O- parts from autozone? the uphill vs. downhill makes me suspect the fuel pump is weak, any ideas?
