Shift Fork Problem
howley brad
my problem is that from neutral i cant get into first gear the only time i am able to get into first gear is when i gear down and stay in first then from there i can just go again but if i take it out of first and try to put it back in it will just grind no matter what ... iv been told this is a shift fork problem and if so how to fix it
Start with the simple and check your clutch fluid level, a low fluid would cause this type of problem and would indicate ether you have a slow leak in the system or your clutch is worn and needs to be replaced soon. If it's your clutch that needs to be replaced soon, take note that you can have your fly wheel resurfaced rather then replace is if it's not past the wear point of no return. Also it would not hurt to replace your transmission fluid and inspect the condition or the fluid and see if there ate any excessive metal shavings in with the oil. :eek:
Good luck and keep us all posted on your trany problem and hope it's a simple fluid leak that is a simple fix.
theres no such thing as tanny fluid in a manual
1996 GMC TRUCKS SONOMA 4.3L 6-cyl Engine Code [W]
Manual Transmission,NV1500......GLS GM part no. 12377916 or equivalent
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Manual Transmission, NV1500..........2.7 liters
Manual Transmission,NV3500......GLS GM part no. 12345349 or equivalent.
Manual Transmission, NV3500..........2 liters
TORQUES:
Manual Transmission NV1500
Fill Plug 17 ft/lbs
Drain Plug 27 ft/lbs
Manual Transmission NV3500
Fill Plug 44 ft/lbs
Drain Plug 44 ft/lbs
You'll find the drain and fill plugs on the side of the transmission.
Wish my standard transmission didn't need transmission fluid servicing every so often to keep it running without problems. :rolleyes:
Sorry forgot you had the 1991 2.8 V6
1991 GMC TRUCKS SONOMA 2.8L 6-cyl Engine Code [R]
Manual Transmission,BW T5......GLS GM recommends Part No. 88861800 (Canada 88861801) or equivalent for manual transmission
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Manual Transmission, 5-SPD W/ TOPC..........2 liters
TORQUES:
Manual Transmission BW
Fill Plug 17 ft/lbs
Drain Plug 30 ft/lbs
Manual Transmission 4-SPD W/ TLC
Fill Plug 17 ft/lbs
Drain Plug 17 ft/lbs
Fill Plug 44 ft/lbs
There you go, that's better and good luck.
