i need your to help to find out what is the problem of my 1996 savana conversion by starcraft with 43,143 kilometers only. its V8 350 vortex engine i never had a problem since i bought this van in 1997 the van has been stored in my carport every winter and i always filled it up with esso gasoline with no problem whatsoever, but last october i filled it up with husky gasoline and stored in my carport and disconnected battery cable as i used to do it for the past 12 years. then my problem started last march when i attempted to start the van, it seems that there is no enough gasoline going to fuel system. i tried to start the van for two week but to no avail. a friend of mine hooked his engine analizer and there was no code found. he took the air filter cover and sprayed the air intake with gasoline and few clicked the van started.since march i have been doing this in order to start the van once i started there is no problem during the remainder of the day. i took for a drive for more than an hour there is no problem starting. acceleration smooth, responsive and no hesitation so i assumed that my fuel pump and filter is working well. since march this has been going on. if you gurus can help me i appreciated well. thank you
