Strange braking issue
goatmonkey
Yet another question for the experts here. This forum rocks, and has saved me a couple thousand bucks in shop labor costs already :D
My brake pedal vibrates very slightly once the truck slows to around 5mph, then stops vibrating less than ten feet later. The brakes work perfectly, as I just changed pads & rotors all around. If I pull the ABS fuse, the vibration doesn't happen.
It does it on dry/wet/snowy/sandy/whatever pavement.
I've been told by non-experts that this is a GM/ABS thing. I'm going to put up with it until I pass the safety, then pull the fuse again. ;)
Sensor maybe? Or is it really a GM thing?
You need to do a abs sensor cleaning on both front wheel bearing to correct the problem.
Takes no parts just labor. Remove sensors from wheel bearing file off the rust till surfice is flat reinstall. Its that easy.
