suspension knocking? 91 gmc jimmy 4.3 liter v6?
Stan
ok so i took it in to have my shocks checked and they said they were fine but
when i hit a bump or turn somethings kocks (knock knock) maybe its my ball joints? i thought it was the shocks bottoming out but they're still springy when i rock the truck and dont make the noise when i rock it.
just when i turn or hit bumps.
i dont know what other info to give you as its a mistery for me as well
Check your sway bar end link for play or worn bushings, if you have a 4wd inspect the torsion bar isolator support. Common for the isolator support bushings to go bad and make noise going around corners and over bumps. :eek:
