T Case issue, in need of some expert advice asap
Bluenote
Winnipeg Canada
2002 2500 HD 6.6 Diesel
Allison Trans ( New )
Encoder motor ( New )- checked to make sure it works and works
3 button switch, no Auto 4wd on dash
Now we changed it and it changes in 4 hi and 4 low, you can actually feel the diff in gear ratio, but it remains in 2wd, buttons light up as they should. But the front drive shaft will not turn, not even off the ground in the air. You can cycle through all the settings and it will not turn, so this rules out my hubs locking up obviously.
Now I read this issue all over the place and everyone or shop right away says new T case. Now I am not expert on T cases in these trucks at all. So you need to school me on them, But from what I see they are chain driven, kinda like a Fwd trans. I was told they were like a transmission with clutches and such.......I also was told the pump may not be working, and also the vacume, but again I am no expert and I really do not want to be taken advantage of here and get sucked into a used T Case.
Oh ya also the odd part it makes no noise (as in the case of something broken at any speed ), and the drive shaft when engaged is not spinning by hand, it is solid, so it is engaged I am guessing to a point, but not enough? You can with truck off and just key on turn the shaft manually and the two front tires turn.
If someone could give me a heads up on this before i get taken to the cleaners, that would be great.
thanks for any help.
Jeff:confused:
Solved....
The encoder motor was going, but I put a new one in anyway.
The case itself, both Forks inside were worn right down, this is why it was not engaging enough to get into 4wd, I also had them put in the retainer clip that everyone suggested as GM seems to have not thought the T case out to well and they have a tendancy to fall apart.
All in all, it cost me for two forks, seals, welded a small crack in the case, and that retainer , removed and reinstalled with a year warranty $1350, I used one was going to coast me $1300 and a rebuilt was sitting at $2000.
