Hi all,
My 1999 Sonoma 4.3 automatic with 203,000 miles has a temperature gauge problem. At least I think its a gauge problem.
Gauge goes to normal operating temp ( halfway)
and then after a few minutes it pegs to the right and the check gauges light comes on. Then it goes back to the halfway point and the light goes off, then it goes to three quarters, then to halfway point. All within a few minutes.
When the gauge acts erratic, i notice that only sometimes the heat blows cool, sometimes blows warm, sometimes it is stays blowing hot.
Radiator replacement 2008
Thermostat replacement 2010 (I replaced it then, due to the same problem as i have now)
full coolant level, coolant is clean, no leaks, no blowing out the tailpipe, no mixing with the oil. no bubbling from the overflow tank either.
recently replaced the smog pump and check valves, but i doubt this has anything to do with it.
Any advice is appreciated.
Thank you.
Thank you.
