Thanks! Question is whether to do now or wait until it acts up. I guess I shoul be on the watch for sime sign of inadequate cooling. Part cost is $200 (US) from Autozone.
You could always do the Salvage yard and pick up the upgrade fan clutch for the Envoy. I believe the upgraded ones are the late 2005 and newer, the new design EV fan clutch has been installed on production vehicles from the end of 2005 model year production (June 2005) and all 2006 model year vehicles. The new design EV fan clutch may also be present on vehicles serviced with this new part per Corporate Bulletin Number 04-01-38-019A or for other service related conditions. The updated design of the electro- viscous (EV) fan clutch helps improve A/C performance but may also produce some additional fan engagement noise.
Do NOT replace an EV fan unless a specific condition related to the EV fan is identified using SI diagnostics. If the fan has a condition that warrants replacement, a DTC should set and/or SI diagnostics should lead to the replacement of the fan clutch.
Operating Characteristics of the Electro-Viscous (EV) Fan Clutch
Changes to the EV fan clutch to improve the HVAC performance basically increase airflow in certain conditions. It is now possible during start up for the EV fan clutch to be engaged and match engine speed for about 1 minute depending on driving speeds (with lower speeds having a longer disengagement time) producing some noise/flare. The noise/flare will most likely be intermittent and can be dependent on the following conditions:
• Fan clutch valve orientation, with check ball at 11:00 position as viewed from front of vehicle when the engine is stopped.
• HVAC or powertrain cooling conditions when the vehicle is shut off.
• Parking incline - vehicles parked nose up on a 16% or higher incline (such as vehicles coming off transport or parked on steep driveways) may have prolonged fan noise/flare until the fluid is pumped out of the working chamber of the fan. These conditions can occur in as little as ten minutes. Once the vehicle is not parked in these conditions, it should operate as expected.
• Please note that if the vehicle is parked nose down with a 16% or more decline, the EV fan clutch may have a delayed engagement response.
Important: Do not replace EV fan clutches for these conditions listed above; they are expected vehicle characteristics. If the fan clutch is truly operating at a speed higher than intended, a DTC P0495 or P1484 should set. Additional codes are available for other conditions
Diagnostic Tips
Depending on the vehicle year, the Tech-2 may allow some EV fan control using the special functions application of the Tech 2 (refer to the proper SI documentation). If this function or a fused jumper wire is being used to check EV fan response, there may be a delay in fan response (up to 2-3 minutes depending on conditions, please refer to SI diagnostics).
The desired fan speed and actual fan speed data (on the Tech-2) can be misleading. The desired fan speed is comprised of the maximum of multiple parameters (for example engine coolant temp, A/C pressure, etc.) and may not be the ruling desired fan speed parameter. The end result may be that the actual desired fan speed is lower than what is displayed. Additionally, the desired fan speed may be higher than the current engine speed. The fan is limited by the current engine RPM and will max out at about 3500 RPM under full manual fan engagement request along with a corresponding engine RPM speed. The 4.2L I-6 (LL8) engine's desired and actual fan speeds will usually be closer to each other than the 5.3L V-8 (LM4 or LH6) or the 6.0L V-8 (LS2).
Listed below are the cars and trucks the fan clutch is used in so your not limited to finding one for your Envoy if you do go to the Salvage Yard. Call around $25.00 to $50.00 at the Salvage yard since they have many of these go through there yard and will have 90 day warranty, but i am sure you can talk them to 2 fan clutch for $50.00 as long as you pull them off your self.
OE #: 15293048, 15192192, 15116115, 10383029, 25790869
The clutch is the latest revision, part number 25790869.
See below for a listing of all applications of the clutch:
Year Make Model Engine Application Note
# 2006 SAAB 9-7X: 5.3I V8 - 5.3L (325 CID): GAS: FI: N Electric
# 2006 SAAB 9-7X: 4.2I L6 - 4.2L (256 CID): GAS: FI: N Electric
# 2006 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 ISUZU ASCENDER: LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 ISUZU ASCENDER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: XL SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMCS15 ENVOY: XL SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: XL DEN V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 GMC S15 ENVOY: SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 GMC S15 ENVOY: DENALI V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBLAZER: SSV8 - 6.0L (364 CID): GAS: FI: N: H Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LT V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 CHEVROLETS10 TRAILBLAZER: LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006
CHEVROLET S10 TRAILBLAZER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006
CHEVROLET S10 TRAILBL.: EXT LTV8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 CHEVROLETS10 TRAILBL: EXT LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 CHEVROLETS10 TRAILBL.: EXT LS V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006
CHEVROLET S10 TRAILBL.: EXT LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2006 BUICK RAINIER: CXL V8 - 5.3L (325 CID): GAS: FI: N: M Electric
# 2006 BUICK RAINIER: CXL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: S V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 ISUZU ASCENDER: S L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: LS V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 ISUZU ASCENDER: LS L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 ISUZU ASCENDER: LIMITED V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 GMC S15 ENVOY: XUV SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XUV SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XL SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: XL SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: SLT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005 GMC S15 ENVOY: SLE L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005
CHEVROLET S10 TRAILBLAZER: LTL6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005
# 2005
CHEVROLET S10 TRAILBL.: EXT LT V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005
CHEVROLET S10 TRAILBL.: EXT LT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2005
CHEVROLET S10 TRAILBL.: EXT LS V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005
# 2005 BUICK RAINIER V8 - 5.3L (323 CID): GAS: FI: N: M Electric
# 2005 BUICK RAINIER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 ISUZU ASCENDER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY: XUV V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 GMC TRUCK S15 ENVOY: XUV L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 GMC TRUCK S15 ENVOY: XL V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004
CHEVROLET S10 TRAILBLAZER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004
CHEVROLET S10 TRAILBL.: EXT V8 - 5.3L (325 CID): GAS: FI: N: P Electric
# 2004
CHEVROLET S10 TRAILBL.: EXT L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2004 BUICK RAINIER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2004 BUICK RAINIER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 ISUZU ASCENDER V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2003 ISUZU ASCENDER L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003 GMC TRUCK S15 ENVOY: XL V8 - 5.3L (323 CID): GAS: FI: N: P Electric
# 2003 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2003
# 2003
# 2003
# 2002 OLDSMOBILE BRAVADA L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 GMC TRUCK S15 ENVOY L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002 GMC TRUCK S15 ENVOY: XL L6 - 4.2L (256 CID): GAS: FI: N: S Electric
# 2002
# 2002
