So when driving around 45-50 mph my transmission can't decide which gear it wants to be in. It constantly shifts back and forth from fourth to fifth(overdrive?) until i either speed up a bit or engage the tow/haul switch and then it goes away. Would this be a computer issue or something internal? TIA!
Put a transmission line pressure gauge ($55 shipped on Ebay, or visit a local trans shop) on the pressure test port and go for a drive to verify proper line pressure. Base pressure at idle in P,N,OD should be around 70psi and around 140psi in R. Max line pressure should be at least 190psi at WOT in 1st or 2nd, 225psi is optimum. If base pressure is low, trans or pump is worn out. If max pressure is low, check EPC solenoid. If reverse is slow to engage, and line pressure does not come up to at least 130psi in reverse, replace the boost valve with a Transgo 0.500" boost valve (easy fix in pan).
Check TPS for smooth and linear electrical response over the entire range of motion. If not, replace the TPS. Log a Tech2 scanner to see if the PCM is doing it, if not, increase line pressure for fourth at low MAP values. You might get luck also if you just need your transmission serviced, due to a dirty transmission filter and replace your boost valve also.
When you use your tow mode, it rises your line pressure by lowering your voltage to the EPC valve in your transmission. Cross the fingers and hope that a transmission service and a boost valve replacement will cure your transmission issues. Common for a worn boost valve to kill the 4L60E transmission by having it slip and gear search like what you are experiencing.
You can remove the checkball from its cage in the case in the rear of the transmission may help (must remove valve body), removing that checkbal firms up TCC engagement. It makes TCC lockup feel more like an upshift. The checkball was put there to soften the TCC feel, I dont mind a more firm feeling myself, I have done this mod myself long time ago when my Jimmy was new and the only draw back was braking traction on wed slippery roads when transmission shifts gears with the skinny peddled 3/4 down.
http://www.compnine.com/index.php?u...delid=7036&capuid=1&majorgroup=04&grouptype=B
