Chris Bain
Have a 1997 Chevy S-10 with 4.3 automatic trans,when you first crank it you have to cut the ignition key on and off at least 3 times,then truck will crank and run fine as long as you crank it back up within 10-15 minutes. Then you have to repeat key on/off process again. Trying to find out the problem. Some think fuel pump or ignition switch troubles, some say starter solenoid, some injector sensor,or even computer trouble. I was needing some help with this does anybody have any input?
