I own a 2001 GMC Jimmy 2door 4x4. I need to locate an opening in the firewall where i can run some axillary light wires. where would this area be located under the firewall??
You can try running the wire through the radio antenna cable grommet. It's located on the passenger side buy the heater housing. Here is a link where the cable is located and how it's run, this way there are no extra holes drilled which would be your next step and buy a grommet to fix over the hole and run the wire through it.
