I found out that you can manually shift the transfer case. I now have the car in 2hi, as it originally was. Now when I try to shift it into 4hi, the lights on both 4hi and 4lo, blink 4 times and go back to 2hi. Doesn't the switch lights act as some kind of DTC code? Also I replaced all the vacuum lines, but I can't find a good vac diagram of which line on the vac switch goes to where. any help on this? I have manifold vacuum but still no vacuum on my actuator .
thanks
thanks
