Vibration Noise
Dyl Pickle
At high speeds (75-80...okay 85) I get a very annoying vibration from what appears to be coming from the passenger-side corner of the dashboard at the windshield. A passenger friend tried to identify where it was coming from but it's either internal or possibly wind seeping through somewhere. Any thoughts?
My 2010 does the same thing, cant figure out what it is either. If you find out, please post it!
I rotate every oil change. Just put a new set of tires on in Nov. Its not a tire problem. Only does it at speeds over about 70. A stiff crosswind seems to make it worse. Tried pulling the antenna off to see if maybe it was the mount, no luck.
Crazy thing is, its not a constant problem.
