What are biggest tires i can put on my 1998 GMC Sierra 4x4?
Blake C
What is the biggest tire size i can put on my 1998 GMC Sierra 4x4 1500 with out a lift kit for mudding?
265/75R16 is the biggest size most tire dealers/installers will put on without having you sign a waiver. Since that is the largest optional size recommended by GM.
The new 285's were a replacement for 265's that were optional equipment when new and the 245 size should be stock on any new 1500 series but you can put a set of 31 12.50s on mine no problem.:rolleyes:
Note:
265.75.R16 should fit 2wd, 285.75.R16 should fit a 4X4 although it is possible that one might need to adjust the front torsion bars slightly. The front is the main place you have to worry about fit.:eek:
Good luck and hope this helps. http://www.tirerack.com/ ;)
