What is the stock rear and front gear ratio for a 2005 GMC Sierra 2500HD truck?
Professional Hitman
I want to know what the rear wheel gear ratio and front wheel gear ratio is for my truck. I'm using a chip programmer and I need to know.
10 points to the first true answerer.
Look in your glove box for the PRO codes.
Here are the Pro code for the rear ends to your Sierra
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSI TRACTION)
HC4 -- AXLE REAR, 4.56 RATIO
Open Your glove box and look inside it. Should be a list of codes on the bottom.
Example: GU6 G80 According to that, you'll have a 3.42 posi
