The 4.8 L and the 5.3 L are smaller truck versions of the LS1 and were designed to replace the 305 and the 350 in trucks. Both the 4.8 L and the 5.3 L share the same engine block and heads. Although the block of the 4.8 L/5.3L looks similar to the LS1, they are not of the same blocks.
The Vortec 4800 is a small block V8 truck engine, It is the smallest of the Generation III Vortec truck engines and was the replacement for the 5.0, L 5000 L30
The Vortec 5300 is a V8 truck engine, It is a stroked (by 9 mm) version of the Vortec 4800 and replaced the 5700 L31.
The 6.0 L is a larger truck version of the LS1 and was designed to bridge the gap between the new small blocks and big blocks in truck applications. There were two version of this engine the LQ4 and the LQ9 being more performance oriented. Although the block of the 6.0L looks similar to the LS1, they are not of the same blocks also.
The Vortec 6000 is a V8 truck engine also, It is an iron/aluminum (2000 model year engines had cast iron heads) design and produces 300 horsepower to 345 horsepower.
All these engines are of the generation III from 1997 to 2007
The engine blocks were cast in aluminum for car applications, and iron for most truck applications (notable exceptions include the
Chevrolet TrailBlazer SS,
Chevrolet SSR and a limited run of
Chevrolet/GMC Extended Cab Standard Box Z71 Trucks). The architecture of the LS series makes for an extremely strong engine block with the aluminum engines being nearly as strong as the iron generation I and II engines and with the iron LS engines far exceeding the capabilities of the previous two generations. The engine also introduced coil-on-plug ignition. The traditional five-bolt pentagonal cylinder head pattern was replaced with a square four-bolt design, and the pistons are of the flat-topped variety. The cylinder firing order was changed to 1-8-7-2-6-5-4-3, so that the LS series now corresponds to the firing pattern of other modern V8 engines.
