What's the average cost to replace freon in a GMC Suburban?
LuvNMama
I've never taken the truck in for AC problems before and don't want to be taken for a financial ride. The truck is 10 years old so I'm sure it's due, the air blows fine it just blows warm air!
shouldnt be more then 100. look for coupons in your local paper. it only takes a few ounces of freon.
Find a good repair shop and have them look at it they will check to see how much R-134 is in there to begin with then recover what is in there do a leak test and refill it it should be less than a hundred dollars.Some places will check it for free and just charge you for the R-134 that they use which is around 40 dollars a pound that they use to refill your system.Then there is another option you can get what you need from any parts store such as the oil it only takes about 8 ounces or 1 can look under your hood and there will be a sticker that will tell you what to use either ester oil or pag oil and how much freon you need it should be around a pound to 2 pounds if you have rear air and the stuff you need to have you add it yourself they can tell you what you need.
