Does anyone know where I can find out what the specs are for the stock 17" wheels that came on my '07 Sierra Classic?
Mainly width and backspacing.
Also,is there somewhere I can find out what options came on it, such as differential ratio, limited slip, etc. I bought it used so I don't know much about the specs.
Thanks
The most accurate method of determining a rear axle gear ratio is to look in the vehicle manufacturer's service manual. The following Regular Production Option (RPO) codes identify the rear axle and trans axle overall final drive gear ratio's. These codes can be located on the RPO sticker in the glove box or in the trunk on most GM vehicles. These codes are arranged in alphanumeric order. Please refer to the information below, and this should cover all of the GM rear ends.
RPO CODE DESCRIPTION RATIO
F16 TransAxle Final Drive 2.53
F17 TransAxle Final Drive 2.84
F18 TransAxle Final Drive 2.65
F25 TransAxle Final Drive 3.32
F29 TransAxle Final Drive 2.82
F36 Axle Front 2.19
F45 Axle Front 2.93
F47 Axle Front 2.73
F57 Axle Front 3.15
F62 TransAxle Final Drive 2.39
F67 TransAxle Final Drive 3.19
F68 TransAxle Final Drive 3.45
F75 TransAxle Final Drive 3.18
F77 TransAxle Final Drive 3.73
F79 TransAxle Final Drive 2.97
F82 TransAxle Final Drive 3.23
F83 TransAxle Final Drive 3.05
F90 Axle Front 2.73
FA0 Rear 5.77
FA1 Rear 2 SPEED 4.88/6.94
FA2 Rear 2 SPEED 4.88/6.94
FH5 TransAxle Final Drive 2.81
FH6 Axle Front 3.64
FH7 TransAxle Final Drive 4.12
FH8 Axle Front 2.40
FH9 TransAxle Final Drive 2.60
FJ1 Axle Front 4.18
FJ2 Axle Front 3.74
FJ3 TransAxle Final Drive 3.35
FJ4 Axle Front 4.53
FJ5 Axle Front 4.19
FJ7 Axle Front 4.56
FP0 TransAxle Final Drive 2.55
FP1 TransAxle Final Drive 2.72
FP2 TransAxle Final Drive 3.58
FP3 TransAxle Final Drive 2.73
FP4 TransAxle Final Drive 2.69
FP5 TransAxle Final Drive 2.95
FP6 TransAxle Final Drive 3.54
FP7 TransAxle Final Drive 3.73
FP8 TransAxle Final Drive 3.54
FP9 TransAxle Final Drive 3.54
FQ2 TransAxle Final Drive 3.48
FQ3 TransAxle Final Drive 2.86
FQ4 TransAxle Final Drive 3.57
FQ6 TransAxle Final Drive 4.12
FQ8 TransAxle Final Drive 2.96
FQ9 TransAxle Final Drive 3.21
FR2 TransAxle Final Drive 2.93
FR3 TransAxle Final Drive 3.69
FR6 TransAxle Final Drive 3.84
FR7 TransAxle Final Drive 3.95
FR8 Axle Front 4.17
FR9 TransAxle Final Drive 3.29
FV0 TransAxle Final Drive 3.67
FV1 TransAxle Final Drive 3.72
FV2 TransAxle Final Drive 4.18
FV3 TransAxle Final Drive 3.11
FV4 TransAxle Final Drive 3.71
FV5 TransAxle Final Drive 4.19
FV6 TransAxle Final Drive 4.24
FV7 TransAxle Final Drive 4.29
FV8 TransAxle Final Drive 4.31
FV9 TransAxle Final Drive 4.53
FVO TransAxle Final Drive 3.67
FW2 TransAxle Final Drive 3.06
FW3 TransAxle Final Drive 4.02
FW4 TransAxle Final Drive 3.89
FW5 TransAxle Final Drive 4.10
FW6 TransAxle Final Drive 3.42
FW7 TransAxle Final Drive 3.83
FW8 TransAxle Final Drive 4.28
FW9 TransAxle Final Drive 3.43
FWS TransAxle Final Drive 4.10
FX1 TransAxle Final Drive 3.94
FX2 TransAxle Final Drive 2.66
FX4 TransAxle Final Drive 3.35
FX8 TransAxle Final Drive 3.61
FY1 TransAxle Final Drive 2.36
FY3 TransAxle Final Drive 3.79
FY5 TransAxle Final Drive 3 52
G11 TransAxle Final Drive 2.56
G44 Axle Rear 3.07
G72 Axle Rear 2.14
G75 Axle Rear 3.62
G76 Positraction Rear
G80 Axle Positraction, Limited Slip
G81 Positraction Rear Axle
G82 Axle Rear 4.56
G84 Axle Rear 4.10
G86 Axle , Rear, Limited Slip
G87 Ring Gear, 8.50 Inch
G89 Ring Gear, 7.50 Inch
G90 Rear 3.15
G91 Special Highway Rear Axle 3.08
G94 Axle Rear 3.31
G96 Axle Rear 3.55
G97 Axle Rear 2.73
GH0 Axle Rear 3.54
GH2 Axle Rear 2.29
GH3 Axle Rear 2.77
GH4 Axle Rear 2.92
GH7 Axle Rear 2.73
GJ1 Axle Rear 5.38
GJ2 Axle Rear 5.13
GK7 Axle Rear 4.78
GK8 Axle Rear 4.33
GK9 Axle Rear 4.63
GL0 Axle Rear 5.13
GL3 Axle Rear 6.17
GM1 Axle Rear 2.59
GM2 Axle Rear 3.44
GM3 Axle Rear 3.45
GM4 Axle Rear 3.67
GM5 Axle Rear 3.89
GM6 Axle Rear 4.22
GM7 Axle Rear 3.68
GM8 Axle Rear 2.56
GN9 Axle Rear 4.11
GS1 Axle Rear 2.73
GS3 Axle Rear 3.73
GS4 Axle Rear 3.70
GS5 Axle Rear 4.11
GS6 Axle Rear 4.56
GS8 Axle Rear 3.94
GT1 Axle Rear 2.56
GT2 Axle Rear 2.29
GT4 Axle Rear (DUP WITH 5 X 1) 3.73
GT5 Axle Rear (DUP WITH GT8) 4.10
GT7 Axle Rear 3.33
GT8 Axle Rear (DUP WITH GT5) 4.10
GU1 Axle Rear 2.41
GU2 Axle Rear 2.73
GU3 Axle Rear 2.93
GU4 Axle Rear 3.08
GU5 Axle Rear 3.23
GU6 Axle Rear 3.42
GU7 Axle Rear 2.77
GU8 Axle Rear 3.90
GU9 Axle Rear 3.91
GV0 Axle Rear 3.55
GV1 Axle Rear 2.73
GV2 Axle Rear 5.83
GV3 Axle Rear 3.08
GV4 Axle Rear 3.36
GV5 Axle Rear 3.55
GV7 Axle Rear 4.11
GV8 Axle Rear 2.72
GV9 Axle Rear 4.25
GW2 Axle Rear 2.56
GW3 Axle Rear 2.56
GW4 Axle Rear 3.31
GW5 Axle Rear 2.73
GW6 Axle Rear 3.27
GW8 Axle Rear 4.10
GW9 Axle Rear (DUP WITH GU3) 2.93
GX1 Axle Rear 3.70
GX2 Axle Rear 3.07
GX3 TransAxle Final Drive 3.33
GX4 Axle Rear 3.75
GX5 Axle Rear 4.09
GX6 Axle Rear 3.53
GX8 TransAxle Final Drive 3.74
GY2 Axle Rear 3.31
GY3 TransAxle Final Drive 4.29
GY4 Axle Rear 4.53
GY5 Axle Front 3.65
GY7 TransAxle Final Drive 4.18
GY9 Axle Rear 4.31
GYS TransAxle Final Drive 3.65
H01 Axle Rear 3.07
H04 Axle Rear, SINGLE SPEED 4.11
H05 Axle Rear 3.73
H12 Axle Rear, 21000 LBS, EATON 21065S, SINGLE SPEED
H42 Axle Rear 6.17
H43 Axle Rear 5.43
HA3 Axle Rear, SINGLE SPEED 5.29
HC4 Axle Rear 4.56
HC7 Axle Rear, 7500 LBS, SINGLE SPEED 5.13
HC8 Axle Rear, SINGLE SPEED, TRUCK 3.21
HC9 Axle Rear 5.13
HE3 Axle Rear, 3500 LBS, SINGLE SPEED, 3.07
HE4 Axle Rear 3.40
HF7 Axle Rear, 10000 LBS, DANA 70, SINGLE 4.56
HF8 Axle Rear 4.88
HJ1 Axle Rear 4.55
HJ2 Axle Rear 5.86
HJ3 Axle Rear 4.75
HJ4 Axle Rear 6.50
HJ5 Axle Rear 5.57
HJ6 Axle Rear 4.78
HJ7 Axle Rear 4.88
HK1 Axle Rear 2.87
HK3 Axle Rear 6.14
HK9 Axle Rear 10000 LBS, SINGLE SPEED 5.86
HO4 Axle Rear 4.11
HO6 Axle Rear 4.63
As for your questions to the wheel size, there are endless combination's so here is a link to Tire rack.
http://www.tirerack.com/
