Where is the A/C Relay
Man In Black
On my 93 Sierra pickup I'm not getting any power to the air condition compressor clutch. The fuse is good in the fuse panel and the wiring diagram is showing some kind of a relay for the compressor with four wires going in, and there is only two wires going into the compressor clutch and I don't have any power at those with the air turned on, and the clutch won't kick in. I can't find the location of that compressor clutch relay, anybody know where it is located so I can trace the power to and from it ?
MIB, you should check the low pressure switch at the accumulator/dryer first. It's the quart sized aluminum container close to the firewall.
