yzwarrior250
...windows continue to work properly? The vehicle is a 93 GMC Jimmy; the problem is that the front windows will only work for a couple seconds at a time, then will stop moving, as if there is no power. The rear windows roll up and down with no problems; what would most likely be the cause of the front window problem?
if you leave the switches alone for a few minutes, the windows will start moving again for a couple more seconds and then quit again for a few more minutes.
