Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
🔍 Like our community? You can tell Google to show you results from this site more often. Just Click Here and then click the empty checkbox on the right side of our name.
When cold in winter you should see 80psi on start then pressure at operating temp should be 40-45psi and this is normal. Your user manual it says only 5w-30 or 10w-30 and do not use additives. Thicker oil viscosity like cold engine oil will offer more resistance to flow that would increase your oil pressure reading.
