wont start.
sherie
This might seem long, but bear with me. I have a 1999 chevy suburban (5.7L) 4x4. I drove it, was running fine, I parked it, came out 2hours later and it wouldn't start. It cranks but does not start. I had just refueled so it had a full tank of gas. I thought maybe I got some bad gas so I had it towed home and replaced the fuel filter. That wasn't it. I had someone come test the fuel pressure and it did not have enough pressure so they advised me it was the fuel pump. That wasn't it. I still don't have enough fuel pressure. It will start with starting fluid, so I know that for whatever reason it is not getting fuel to the rail. I have also noticed that the gauges on the dash work, but the fuel gauge sometimes goes crazy when you turn on the key. And there is a clicking from the relays under the dash (down by the e-brake). (I don't even know what these relays are for) I need some help. I am out of ideas. Any thoughts about what could be going on would be greatly appreciated.
Thanks, S.
wont start
Sherie = did you ever figure out what the no start problem was ? I have the same yr & model suburban and am having the same problem?
Please let me know asap...thanks!
