jbeambabie
- Jul 14, 2014
First off... let me introduce myself. My name is Kevin and I have an 01' Sonoma 4x4. I am getting this odd problem (at least to me) that makes the truck shift hard. It winds out to 4300 RPM then shifts real hard. The speedo also drops to zero, then back up to correct speed, then to zero, then back up. The ABS, Brake, and check engine light come on when this happens. The error code read that it could have been the variable speed sensor in the trans. A trans shop replaced it and it did not correct the prob. They told me that the trans was fine and that I needed to take it to an engine mechanic. Does anyone have any idea what could be causing this?
