mwhitney50
- Feb 22, 2014
I had an oil leak from the distributor. When I went to re-installed all the plastic connector were old a fragile. Small clips broke... While timing the ignition, I shut off the engine to tighten the bolt. Next no start! no voltage to coil from harness. Replaced the entire distributor with a re-manufactured unit (due to the old condition of the original). No voltage still, replaced spark control, now have voltage but no spark. Replaced coil, now voltage in to coil and voltage back to distributor. no start, no spark on the coil wire(hei test plug). Also for giggles new ECM with old eprom.
Need help!
Need help!
