L lenmoreno New member Joined Dec 30, 2010 Messages 7 Reaction score 0 Points 0 Dec 30, 2010 #1 changed out spark plugs and wires, one at a time ...of course. now truck has major problems getting started, could it be a timing issue now
M Molson02536 New member Joined Dec 9, 2009 Messages 3,123 Reaction score 0 Points 0 Location K/W Ontario Canada Dec 31, 2010 #2 lenmoreno said: changed out spark plugs and wires, one at a time ...of course. now truck has major problems getting started, could it be a timing issue now Click to expand... Check your wire leads to the ICM since you were working on your ignition system. Start with that and also try replacing your fuel filter also, doesn't hurt to cover all the bases at this point. Was the right spark plugs used with the proper gap??? Good luck and keep us posted. Last edited: Dec 31, 2010
L lenmoreno New member Joined Dec 30, 2010 Messages 7 Reaction score 0 Points 0 Jan 4, 2011 #3 did use the correct plugs, and gap was .035 fuel filter will be changed ASAP, like today
