1996 GMC Jimmy 4 wheel drive not fully engaging?
Same Problem
I've read this thread all the way through and it is very helpful. What I would like to know is what is the rubber boot called just foward of the Acuator Vacuum. Mine is ripped and I believe that may be my problem on my Jimmy. I know it's been a while since any posted so I hope someone sees this....:(
Its called the 4WD Vacuum Actuator, and yes when that is ripped. It will need to be replaced. http://i.tfcdn.com/img2/z79PcXUAY57...OT9XHyKi76lvYujrneTtV-ps5qOXVZBOni4A/fyVMtP8A
There used in all the 1983 to 2005 Jimmy's I go through a few of them so i foud it better for me to just go after it at the salvage yard. $10.00 gets me 3 of them giving me 2 spare lol. Just make sure there new as possible and you'll be fine.
Good luck and take your time.:D
Molson02536
Vacuum booster
JUST A FRIENDLY FYI
I'd check the good mounted vacuum booster on the drivers side FIRST!!
I am a new owner, the truck was given to me...
I must have dislodged the hose that goes to the canister while repairing the break booster and didn't realize it. This must tie in to the entire system because the minute I discovered it was unplugged, and re-connected it the 4wd worked instantly again.
Don't tear into the headlight or trans. Case lines until you check this first!!
Literally a 2 second fix!
Hope this saves some people some time!
