Might just roll it ove a cliff.....I hav posted her a few times on the gremlin infestation...a few more onths of work and back to square one...so let me start the list and Info..
1998 sls jimmy 2wd
v-6 vortex
heads reconditioned/rebuilt.
fresh oil and 91 octane gas,w 1/2 bottle of SeaFoam in each
ALL filters replaced.
New battery,fully charged., Extra grd added.
all new gaskets on the intake manifold,No vacuum leaks. no fuel leaks.
Fuel Pump Pressure checked , 62psig. during start drops alittle , WHEN running at Idle ,reads 62 psi. steady.
Oil pressure normal,temp normal , etc.
New Cap and Rotor, New spark plugs properly gapped.
Does not blow ant black exaust..very clean,,little grey smoke when Cold,goes away.
New MAP sensor.
New MAF sensor.
New TPS sensor
symptoms
intermittent PO108, only when trying to increase Eng RPM does it code.
Eng will 1st fire start cold in one eng rotation ..as long as i dont do anything it idle like a kitten.
I move the it throttle 1/8" , It will either surge , drop rpms( barely run) or die . like I said when idle its smooth, and may or may not throw a code oif it does its P0108,, listed is the FF data after a 5-10 min idler period,,never touching the Acceleration pedal. OAT 65-70 High humidity (clouds , no rain)
fuel sys1 CL
fuel sys2 CL
Calc Load %4.2
ECT *C 92
stft b1 -24,22
ltft b1 -14.06
stft b2 -24,22
ltft b3 - 17.97
MAP. 98.00
Eng rpm (750-800 at start) 403
MAFs 7.48 gs
TPS 0.0
Take your best Troubleshooting guess ,.I am all ears.. spoke w CAR repair shop for cost ON REPROGRAMMIN>$150. and thru the INTERNET?? wonder If could find that program and do it myself w/ a laptop?
1998 sls jimmy 2wd
v-6 vortex
New MAP sensor.
New MAF sensor.
New TPS sensor
symptoms
fuel sys1 CL
fuel sys2 CL
Calc Load %4.2
ECT *C 92
stft b1 -24,22
ltft b1 -14.06
stft b2 -24,22
ltft b3 - 17.97
MAP. 98.00
MAFs 7.48 gs
TPS 0.0
