718000000089
- Jul 21, 2012
I have a 1999 Jimmy, I am locked in 4wd Hi, when I go to shift into 2wd Hi, the light will flash, clicking from under the vehicle and from the control box by the passengers door and then return to 4wd Hi and I am in 4wd Hi with the front tires locked in gear. If I pull the 4wd fuse out of the panel, the transfer case will shift into 2wd Hi, but I lose my fuel guage and the battery light comes on, this is the way I'm driving the vehicle now. If I put the fuse back in, when I start the vehicle the vacuum actuator under the battery moves and stays in place. When I first purchased this vehicle I could not shift from 4wd Hi into 4wd Lo, the lights would flash and the clicking sounds would be present but would not lock into 4wd Lo. I have not used the Low Range for several years, this could be a separate problem. I did replace the vacuum lines under the hood and replaced the electrical switch on the dash, I also swapped the control box by the passengers door. It has always shifted in and out of 4wd drive until this summer. What and where else should I look to correct this problem. Thank you for any input.
