I had my 2000 jimmy radiator flushed about 3 mos ago, 2 wks ago,thermostat was sticking as temp.gauge shot up to 3/4,july 4th,vechicle started leaking coolant and some type of water which i thought was from a/c unit.mechanic pressure tested radiator and replaced bad radiator cap.2 days later i drove 2.5 miles to work without using a/c.shut off engine, engine started leaking further back from engine,leak was water.took back to mechanic immediately he said he left car running all day and told me it was my a/c unit,he pressure tested radiator again,checked all hoses.day after i picked up the vechicle i used it without the a/c unit, no leaks.last night i drove it exactly .7 miles shut off engine and noticed it started leaking water about midway back from engine, leaked quite abit and fast, eventually it stopped. since i am a female i am tired of being taken by mechanics, how can the water pump and or intake gasket be checked.i asked my mechanic how i would know if it was the water pump, his reply, you will know, it will start leaking water, helllo, this is what is has been doing.please help or give me a direction to head?
