2001 Jimmy front bearing assembly
soulsiege
I cannot find anything online about 2001 jimmy bearings assembly, every other model has a shaft that goes through the bearings, this model just has a little bracket. I can't for the life of me find out if I need to grease it inside. It looks sealed... As if grease would have no effect.
hub assemblys are usually always sealed, if you have a press you can take apart and put back together but its usaully less expensive just to replace the unit
