2003 Sonoma won't start
saints0513
Yesterday went to warm truck up due to cold, cranked it up and went back inside. 5-7 minutes later, went back out to leave, truck wasn't running, and would not start. It cranks, everything lights up as normal, but it will not start. Battery is only 2 months old, putting out good voltage, not giving me any codes at all, just replaced the fuel filter, just looking for a good direction to start looking at the cause.
Thanks.
Does it usually start on the first turn or does the starter turn it over a fer times before it fires?
Could be the starter not putting out enough power.
Could be that there's no spark, check the wires and plugs and distributor / coils.
check the fuel pumps working, give the bottom center of the tank a tap with a hammer to maybe help the pump start up, if that works then you need a new fuel pump.
