2004 Envoy SLT 4.2L Misfire On Cylinder #4. Put In New Plug, Ignition Coil & Fuel Injector
afili8ter
Hello members,
This is my first post and I am glad to have found this forum. I hope to learn so much here.
Anyway, here's my problem. I bought this Envoy a few months back from a co-worker. The only DTC on my scanner is P0304.
1.
I swapped out the coil from no#4 with different cylinder coils....
2. I replaced the coil with a new one on cylinder #4
3. I replaced the spark plug on cylinder #4
4. I replaced the fuel injector on cylinder #4
still, cylinder #4 is misfiring
I bought a logic probe and have done troubleshooting and I have voltage, a signal and a ground reading on the coil plug connection on #4, and it still misfiring.
I have tested the fuses and relays, and they're all good. I also tested the connection to the PCM (C2) and it checks out good.
I'm not sure where I should go from here, but I was looking online and it says that it's possible that the fuel filter is clogged or needs to be replaced, but I'm not sure if I should do it until I've done all the troubleshooting needed.
Any help is greatly appreciated!
Once again, glad to be here on this forum
afili8ter
I have the exact same problem !! I was just about to post. I pray we both figure this out
