markroberts0011
2011 Sierra All Terrain that is having a continued issue with a driveline shudder vibration sensation only after I let off the gas to coast and upon light acceleration I feel and hear a vibration for about 1-2 seconds. The best example would be "In Town" driving around 20-30 mph (but not limited to these speeds) and you let off the gas to coast due to trafffic and upon light reaccleration the entire truck has a vibration and brief chatter noise. You can feel this through the vehicle, steering wheel and gas pedal as well you can hear it in different degrees of severity depending on the driving situation. The rpm's must drop to around 900-1000 and upon the reacceleration and they will increase to about 1400 and stay "locked" at this rpm until the noise/vibration abruptly stops and the rpms surge to about 1900 to 2000 and quickly return back down to about 1500 and then shifts fine after that. The whole sensation is about 1-2 seconds and will not happen again until the same conditions are met. When drivnig in town, it will drive you crazy when it happens repeatedly as traffic or conditions slow you down. I have a 3 mile commute to work that is mostly 35-40 mph and it happens 20-30 times during this commute. I am a service manager for another one of our franchises and can understand both sides of the issue here. What I need to know is if anyone else experiences this issue and if so, has there been any fix? To date, our GMC dealer has replaced the torque converter assy , but now they think it has something to do with the 8cyl to 4cyl Eco mode? There are never any DTC codes or apparent faults.
If this is normal for these trucks, I can accept that even though I would not agree that a $44k truck should do this. I am not sure what else to recommend for repair at this point and I think the tech is giving up on trying to find the root cause? If you have any insight or experience that would be helpful, please feel free to share. Thanks!
