I am looking for a little advice on my Truck. Any help would be great. I will try to keep this short but it is along story.
I purchased my 2013 GMC Sierra 4x4 Z71 with the 5.3L V8 new in 2013. At 18000 miles approx. I had a check engine light and it started to idle rough. Took it to a dealership and they told me the spark plug in cylinder #1 was bad and they replaced it along with some other minor things like changing a valve cover gasket. I thought no big deal and went on.
Almost exactly a year later at 38000 miles The same thing happened only this time the traction control lights and stabilitrac lights were flashing as well. Basically the same answer from a second dealership (this time the one I purchased from). Spark plug in cylinder #1 was fouled and needed to be replaced, on my dime this time. After arguing a little bit and questing why I was now on my third spark plug they dealer said it looked like the plug was fouled on oil and I would do an oil consumption test.
I started that and was told to bring it back when the oil level was below full. Since they over filled it by at lease a quart (cant get them to admit it and didn't take it back immediately so that is my fault) it took until 3000 miles and it was .5 qt. low. I was told to bring it back at the oil change mark and get it checked then.
So 2000 miles later I took it in and was told it was 1.5 qt. low. Which is out of spec as far as I know.
Then I was told I was going about the test all wrong and need to bring it in every 1000 miles to get it tested. So now I get to start all over.
I was also told I needed at least 5 times of it being low to prove to GM it is an issue.
To me 2 fouled plugs in the same cylinder and loosing 1.5 qts over 2000 miles should be more than enough proof there is something wrong but apparently not.
My question is what should my next step be? Do I say screw it and by buy a new truck or keep fighting and hope that at some point they will fix it?
