has anyone done a conversion kit to LED bulbs on the 2014 sierra? I have always liked the look of HID kits in the past. I cant find a direct replacement bulb that will do a 5000k color or 6000k color to help match the LEDs around the headlight bezel. I was curious how the install looks after you have to drill a hole in the headlight seals. Does the LED bulb protrude out the back of the removable caps.
I assume if I remove the caps all together, then I'll end up with foggy headlights.
The LEDs are a dual filament like the original bulb and I dont want to lose my high beams.
any input is greatly appreciated.
