What is happening with the braking system. If I'm traveling over a bumpy terrain, and my suspension is being compromised, i.e., (uneven travel of the front tires going up and down), when I push the brake pedal while traveling over a bumpy terrain, the brakes will start to grab in their ABS mold, but a split second later, you can feel the brake pedal starts to pulsate, you can feel the brakes let loose under your foot and the ABS system just seems to release while the brake pedal will suddenly go towards the floor in the next second. Now it doesn't go all the way to the floor completely, (maybe a couple of inches away from the floor, and I'm stretching that only because I have not measured the distance), but if your applying that HARD BRAKING FORCE on the brake pedal, the ABS stops working and the vehicle is not stopping as it should. It more or less starts to glide. This can happen at any speed. It's a feeling like the brakes just stopped working.
Now if I'm on a relatively smooth surface, the ABS system works just fine and none of the above explanation happens.
One other note; brakes and fluid were changed about ten months ago. No fluid leaks then, no fluid leaks now and the master cylinder reservoir is topped off.
Thanks,
Darryl
'94 Sonoma
Thanks,
Darryl
'94 Sonoma
